816B brake parts needed and Advice on brake proble
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Topic: 816B brake parts needed and Advice on brake proble
    Posted: 26 Sep 2010 at 2:42pm
looking for a master cylinder rebuild kit for a 816B. Or the NAPA  kit number. When you push down the brake peddle with the tractor off it makes a hising noise like fluid leaking but none is lost. Think the sound is comming from fluid bypassing in the master cylinder
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 3:11pm
Mechanical linkage , no cylinder . Check your manual for the machine on brake setup.
I believe you are posting on 816 TLB right.?
unsure if it has hyd assist on brakes , know my 715B is all mechanical with wet brakes as part of rear housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 3:49pm
has a hydrolic boost. The guy using it said it made a bang then no brakes. Checked the linkages going to the master cylinder. It is a 816 TLB.
Winston Churchill
