80R mower belt tension
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: 80R mower belt tension
    Posted: 05 May 2012 at 8:13pm
The spring was broken when I got it last month. I rigged the chain up [idler pulley].  I took on a trail run today & it works good, but while its running the belt is kind of jumpy. Should the belt be tight enough not to jump??? and where do i find a new one when this one breaks.  thanks Keith So. Va.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 9:13pm
I think the belts will get a kink in them just from setting and  don't run real smooth...the idler spring is there for a reason. You might want to measure yours before it breaks....Agco might have them but they will be expensive (like over $100). They had their own special "twin rope" belts that probably were better, but for a price. I bought one with a close profile (industry standard) from a bearing supply house for around $20 that has worked well.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 10:33pm
The spring is for constant tension while mowing. The snubber chain is to keep it from bouncing. The manual says to release tension when not in use. Eldon is correct on the belts. Great mowers none the less. Dad's has cut a bazillion acres. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 7:20am
Been around a few of them and it seems to be pretty normal to have the drive belt jumping at times........
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 11:01am
What tractor are you running the 80r on?
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 5:45pm
thanks for the replies, it's rigged up on the WD-45. I say rigged because my 45 has a sort of permanant homemade 3pt. it doe's seem to work well & the price was right, it had been in the back of the boss's shedfor over 20 yr!!! He said I could have it, guess I'm a good employee!!!!! Keith
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 8:37am
A good industrial supply house can get you a belt for around $30.
I just bought a Goodyear belt from Murdoc Electric in Wichia.
The correct  belt is a C-103.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 9:40am
Measure your belt! The 80R used two different lengths, I have the mowers to prove it.
ALLIS EXPRESS!
This year:
