8070ps----7045ps ?
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Topic: 8070ps----7045ps ?
    Posted: 06 Oct 2010 at 11:55am
I've been told the ps transmissions were the same.Does anyone know if they will interchange? I have a 8070ps with imput seal leaking...I can get a completely reconditioned ps out of a 7045 and thought about just putting it in the 8070 when I split it apart.Thanks to anyone who may know.
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 12:45pm
The 8000 series front housing is made a little different than a 7000 series they made it a little wider so they could drill the two bolts for the back hood brace for the 8000s if you can figure out how to make a brace should work for you .Niel
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 10:07pm
If only the input shaft seal is leaking, why do you want to replace the transmission???
