8070 transmission oil cooler
ajl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajl Quote  Post ReplyReply Direct Link To This Post Topic: 8070 transmission oil cooler
    Posted: 17 Apr 2021 at 8:43pm
Is there a transmission oil cooler on these tractors?   There is a small cooler mounted in front of the radiator at the top and I assume that is for the hydraulic oil but I don't see another one for the transmission oil.  Was out this week busting up an old pasture with the tractor and it was pulling fairly hard and the trans oil temp light came on.  I shut it down and let it cool off and then the light went out and I finished the job and it didn't come on again.   Given that the the reservoirs are separate I expected two coolers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 9:05pm
It is a twin cooler. If you look closer there are FOUR hoses going to and from it.
