8070 small pto
zbum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zbum Quote  Post ReplyReply Direct Link To This Post Topic: 8070 small pto
    Posted: 07 Oct 2023 at 12:02pm
I recently bought a ‘82 8070. Equipment has small 1000 pto. Can the large pto be swapped out for a small pto? Or do you have to do the 540/1000 conversion to make this work? Have researched and not sure if I just am missing it? The previous owner used a pto adapter and the splines are pretty worn out, so would like to change out pto shaft.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 12:22pm
Does it just have the small 1000 or can you unbolt the shaft and flip it. Never seen an 8070 with just a small thousand. My 8070 has just a large thousand
Edited by SilverShoes - 07 Oct 2023 at 12:24pm
zbum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zbum Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 1:13pm
Sorry, I think I was confusing in my post. My implements are small 1000 and 8070 has the large. Can the large be swapped out with a small in the tractor. It doesn’t have bolts to flip it. We used to have an 8050 and doesn't have the same pto shaft that you could flip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 4:25pm
You have to put the 540-1000 system in
zbum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zbum Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 4:51pm
Ok, thank you for the replies
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 5:55pm
Just a thought, can your Equipment’s yokes be changed out to match the tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 6:48pm
You don't have to go to 540/1000. You can get a straight small 1000 from an old 7050 or maybe early 7060.
zbum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zbum Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 7:18pm
Yes, but we have a smaller hp tractor with the small 1000 pto and will be sharing equipment.
zbum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zbum Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 7:25pm
Ok, so the 7050 or early 7060 would be a direct pto replacement with the smaller pto? Thanks for the info, I will see what I can find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 7:32pm
540/1000 was always an OPTION in those early days. Many of those 7050/60 tractors never had the option ordered, so they have small 1000.
This page was generated in 0.056 seconds.
