8070 SEAL |
BStone ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Texas Points: 2847 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jul 2011 at 4:40pm |
Mack...Dr.Allis or anyone.8070FWA imput shaft seal leaking.Input shaft has a few small grooves in it.Looks like someone turned it with a pipe wrench or something.Do they make a speedi sleeve for it? I think it will be ok after polishing it out but want to make sure while I have it split.Thanks to anyone that can help.BStone
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2380 |
Power shift? If it is, then yes a speedy sleeve would work .Just need the diameter of shaft and you should be good to go.The trick will be to install it on the shaft with some sort of driver.Good luck.
