8070 power director |
allis/cattle ![]() Silver Level ![]() Joined: 13 Mar 2014 Location: glenella mb.ca Points: 203 |
![]() ![]() ![]() ![]() ![]() Posted: 25 May 2022 at 7:49am |
Would the complete power director from a 8070 bolt into a 7060 ? A friend is having trouble with his and wanted to make it stronger
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21888 |
7060's aren't really known for power director clutch problems. So, what's the whole story ??
We’ll the power director was rebuilt 2 years ago then the motor last year with a new torque limiter it’s slipping again and he’s afraid that the power director will be next. It’s running about 170 horsepower and pulling a 8/16 melroe plow at 5.6 mph burning close to 10 gph
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12171 |
Afraid it might be next? So, you want to just replace it with something that for the most part is the same size? IDK, doc is the expert. If I had a spare $5, I'd say when the motor was redone, something is amiss with the rear main seal, leaking on the torque limiter. I don't understand what symptom you're seeing that makes the PD look bad?
Torque limiter should have had a shield kit installed when it was apart the last time. If the power director was just done 2 yrs ago, it should last for many ore years. Do the TL correctly and get on with farming.
