8070 hydraulic pump |
Post Reply |
Arlis chalmers
Bronze Level Joined: 22 Jan 2020 Location: Pomona ks Points: 10 |
Posted: 23 Jan 2020 at 7:10am |
I was looking at an 8070 for sale, But in the descriptions it says that the HY pump is bad. So my question is where is the hydraulic pump located on the 8070s and is it external or internal? It had Front wheel assist I don’t know if that makes any difference. Thanks in advance!
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
External and located just in front of the right rear axle
Wink I am a Russian Bot |
MACK
Gear pump is different on FWA. MACK
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2856 |
New hydraulic pumps can get spendy. The gerotar pump on my 7580 was bad saved roughly 60% having local hydraulic shop rebuild it.
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6475 |
Which pump, there are three of them. |
Lonn
He'd have to find that out but they are all located in the same spot.
Arlis chalmers
I’m not sure which pump it is from what information I have got from the guy is that it has no lift arms The hydraulic hook ups in the back don’t work and the power takeoff is spinning all the time. I do most of my own mechanic work I have replaced them on like 560 internationalIt was also internal but you didn’t have to split it with this one being in ternal does it need to be split or is there a way to access them
Orange Level Access Joined: 12 Sep 2009 Points: 19499 |
Could be something as simple as a broken spring on the main pumps compensator valve. Don't just go yanking off the pump without proper diagnosis.
Lonn
Arlis chalmers
And where is the location of the three pumps
Remove the right side cab step. Swing out the batteries. Look down inside. To actually work on them, you'll need to drain down the fuel and remove the right side fuel tank.
Arlis chalmers
Thank you guys for all the helpful information I will let you know what the verdict is on if I buy the tractor in with the problem and end up being
festus51
Orange Level Access Joined: 26 Mar 2017 Location: Osage City, KS Points: 1639 |
Arlis welcome to the channel. We are only a few miles apart.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Arlis chalmers
Thank you it’s always nice to converse with other Allis lovers
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2146 |
You're going to need a gauge for this project one way or the other if you're going to try and do this yourself. Regardless of either fixing your old pump or replacing it with a new or used pump, you're going to need to see what pressure it is putting out. A simple low pressure spring on the compensator may very well fix the problem . Plus, the later tractors had a problem with brittle screws that adjusted the pressure and would break and cause low pressure. Easy fix by just swinging out the batteries.
rieg
Silver Level Joined: 17 Sep 2009 Location: swoh Points: 354 |
Welcome to the forum, my 8050 had the same problem last year turned out to be a blown fourth inch o ring between the pumps or some place like that at least that is what they showed me, and told me was the problem. Anyway it works now but has a terrible whining noise that was never there before they think the stand-by pressure needs adjusted. I don't know how they tracked it down hydraulics are out or my comfort zone so I took it to the professionals at our ADCO dealer.
rieg
8070220
Bronze Level Joined: 17 Jul 2018 Location: Red bud il Points: 77 |
I have all 3 pumps here .for sale for a 2wd .if u fine u need the pumps .
Arlis chalmers
What is the difference between the 2 Wheel-drive pumps and the four-wheel-drive pumps
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3238 |
Gear pump and housing are diff - first thing I would do is pull the filter, check for the end cap that goes in the ends of both hyd belly filters. Check the oil level, then put a gauge in the tee in the place to check stand by , see if there is about 400 -550 psi and if not check the low pressure stand by spring on the compensator. IF the spool and spring are ok and there is no pressure - you have a pump problem probably - if you have some pressure - adjust via allen screw or shims. Check the hp by pulling the remote - if no high pressure check the hp spring in the compensator. A service man is necessary if no experience with a compensator system. It is not that complicated a system but a few items control standyby and flow systems on the piston pump.
Arlis chalmers
Thanks for the info how do you change the pto size on the 8070
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7980 |
If you want 540,you change all the pto guts. If you want the little 1000,just put the adapter on it. Why do you want to change what you have?
Arlis chalmers
Well like my brush hog is 1000 the pump for my planter is 1000But my Baler is 540 but on my messy You just put you 1000 or 540 but there are different bolt patterns for each did not know if it had something similar
Then, you want the complete dual speed 540/1000 RPM PTO from a 7010 thru 7060 or 8010 thru 8050. Remove what you have and install the other.
Arlis chalmers
Ok thanks
Post Reply | |
