8070 FWA
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Topic: 8070 FWA
    Posted: 22 May 2025 at 9:25pm
What is my problem? My 8070 front diff. lub. oil is milky colored. I know it has water in it, because, if I pull the drainplug, after it sets a long time, I get water. I have changed the lube oil a number of times. 80w90 85w140 90synthetic, What is going on?
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 3:54am
There will be a vent that should be open to atmosphere that could be broken allowing water entrance, of where you park the tractor is very humid. As the differential cools after usage, it will draw moisture from the moisture laden surrounding air.
Of course all of this precludes submerging the axle into a creek, pond, body of water etc.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 7:17am
The FWA differential compartment breather is a hex plug directly on top of one of the axle tubes. It has a simple O-ring wrapped around a machined groove. Maybe this O-ring is missing ?? The design allows a small pressure build up in the compartment and then the O-ring expands and burps the pressure. When the axle temps cool down it creates a vacuum inside that I always assumed the drive axle seals allowed some air to come back inside to lessen the vacuum. Anyway, check that breather on top and see if the O-ring is missing.
This page was generated in 0.088 seconds.
