8070 670I engine |
   electroman
      Quote   Reply
     Topic: 8070 670I enginePosted: 04 Apr 2018 at 2:40pm  |
   Shop manual says there is an antifreeze drain cock on the right side of engine. I cannot find it. Is it behind the fuel filter?
   Lonn
   Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817  |
      Quote   Reply
     Posted: 04 Apr 2018 at 3:08pm |
   Is there a tank heater installed in that spot?
  Wink I am a Russian Bot  |
   electroman
      Quote   Reply
     Posted: 04 Apr 2018 at 5:14pm |
   Tank heater installed on the cooling water inlet of the oil cooler
   MN_M2
      Quote   Reply
     Posted: 04 Apr 2018 at 6:51pm |
There is a drain plug on the bottom of that water inlet to the oil cooler, with the tank heater in it.  The block drain I think is on the left side under the air conditioner compressor, if it has the cooling system conditioner its on the lower line at the end where it goes into the block, kind of hard to get at.
   electroman
      Quote   Reply
     Posted: 07 Apr 2018 at 5:33pm |
thanks will look for it.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
