8050 steering cyl disassembly |
jb from md
Joined: 06 Apr 2010 Location: Keymar MD Points: 450 |
Topic: 8050 steering cyl disassemblyPosted: 06 Apr 2010 at 9:38pm |
I have an 8050 fwa and the steering cylinder needs repacked. i have repacked other cylinders with good results but i cant seem to get this one apart. most others unscrew but this one has a snap ring. i removed it but cant see what is holding it from coming apart. can someone shed some light on my situation? thanks to all in advance for any help....JB
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2446 |
Posted: 06 Apr 2010 at 10:10pm |
You have removed an external snap ring with eyes-correct. Now gently tap the gland into the barrel until you see an internal ring in the barrel. Use a knife blade or small screw driver to peel it out ,then you can remove the rod and piston assembly.
ScottinSWIL
Joined: 30 Oct 2009 Location: Randolph Co. IL Points: 118 |
Posted: 06 Apr 2010 at 10:11pm |
I think if you have removed the snap ring it should be ready to come apart. I usually use the wand with compressed air held against the fitting that extends the cylinder. Be careful that it wiil come apart in a safe area preferably something a little soft to hit. Service manual is at the farm so not 100% sure on the just one snap ring though?
ScottinSWIL
Posted: 06 Apr 2010 at 10:13pm |
Lynn is correct on the internal ring
jb from md
Posted: 06 Apr 2010 at 10:15pm |
Thanks alot.That makes sense. I figured it would be something simple that i was missing. Thanks again ...JB
