8050 right hand fuel tank |
Unit3
Topic: 8050 right hand fuel tankPosted: 30 Apr 2024 at 8:38pm |
The right hand tank took to leaking. Is there any repair to those plastic tanks?
bigal121892
Posted: 01 May 2024 at 8:42am |
There is, we repaired a leak on an 8070, got the kit from agco, but NAPA or O'Reily might have one as well.
Unit3
Posted: 07 May 2024 at 10:22pm |
I got some stuff from JB Weld. I put it on and let it sit overnight. I put fuel in it this morning and so far it appears to be holding.
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 512 |
Posted: 08 May 2024 at 6:43pm |
I repaired a gas tank on an '02 1500 pickup with a borrowed soldering iron with a wide, flat blade. I emptied the tank first of course, used the hot iron to heat the plastic and a deadblow hammer to move it back into place. Then used the hot blade to smooth it over. It's held for over 2 years now.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8735 |
Posted: 09 May 2024 at 6:01am |
Good luck to you with that. I hope it holds for you for a long time Darrel |
nanuk
Joined: 22 Aug 2013 Location: Saskatchewan Points: 258 |
Posted: 03 Jul 2024 at 4:49pm |
I have a 2003 Ram with plastic tank. Huffer put a hole in it with an awl, took a bit in a cup, left the rest to drain on the ground.
I found a big metal screw and washer that fit snug. Cleaned and roughed the area real well. Gooped them with JBWeld and screwed them in snug, then mucked completely over the whole area. Hasn’t shown a damp spot yet 2 years going. |
AC7060Pd 1975
