8050 rear wheel weights
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Topic: 8050 rear wheel weights
    Posted: 28 Feb 2011 at 3:09pm
Four years ago we replace the rear tires on our 8050 which were loaded with Calcium chloride we didn't replace the blast as we were only using a 15 ft triple k and packers, though when we plow with the five shank wing plow there is a lot of wheel slippage. Just wondering if AC made wheel weight for the rear tires? What are they worth
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:23pm
We have a set of inside wheel weights on the 8050, I think Dad said 800 lbs. each. They came with the tractor when he bought it new. I would have no idea on value or how hard they are to come by. Any weights from the 190's, 200's 7000's and bigger should bolt right on though.
Leon B MO
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:32pm
I have 2 inner weights for sale in east central illinois. Maybe too far away. Send pm if interseted. Randy
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:43pm
I watch some of those inside rear wheel weights sell at auction for $200 each.  I understood they were only 400 lbs each - I don't know for sure?  I have seen tractor weights bring anywhere from $.10-.50 / lb. depending on what it is.
They also made some 300 lb each outside wheel weights for AC tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:55pm
While we are on wheel weights anybody have any weights like these, i have 2 inner weights and could work out a trade. I am in east central illinois. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 7:01pm
Hope this is a better pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 7:02pm
Factory inner wheel weights (for 38 inch wheels) are one piece (require removal of complete wheel to install) and are 400 lbs each. It would take a total of at least four (2 each side) to make up for full fluid on 18.4 x 38's.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 8:16pm
I'm sure SW MO is too far from Ontario, but I have 3 pair (6 total) of the 400 pound weights, and 1 set (2) of big weights that appear to be factory.  I was told the big ones were 1100lbs each.  I would take $200 per pair of the 400 lb weights, and/or $500 for the pair of the big ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:05pm
Thanks Randy, Adam for the information I wish you guys were in ohio Michigan I would gladly drive that distance for the weight I like road trips in to Ohio and Michigan
Morley
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 10:30am
Leon thanks for the tip about looking at other models 190, 200 etc perhaps would be easier to find weight locally
Morley
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 11:02am
Did you check with fawcett's ?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 11:52am
How many of them 400# weights can you stack on each side, is 2 per side the limit? My 8050 that burned up has 2 on each side, and I plan on putting them onto my 8070. Thought maybe while I had it all apart, might as well put 3 or 4 per side, as I have no fluid in the tires. Darrel
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 12:22pm
We have a John Deere 3140 with 18.4 X 38 rims. Put new radials on but didn't put any fluid in tires. Anybody know where we could buy some dry weight?
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 3:21pm
why not load the tires, there is better stuff than calcium cloride available that can be used without damage to the rims, and a lot cheaper than iron weights. and lets face it calcium cloride has rotted out many rims, throughout the years but it usually took 50 years to really mess up a rim unless you ran it on a small leak for years
i like old tractors of all colors
