8050 Power Director |
Post Reply |
randy
Orange Level Joined: 12 Sep 2009 Location: Illinois Points: 1177 |
Posted: 24 Jun 2022 at 6:49pm |
My power director in my 8050 is getting weak, not shifting correct under load. After i split it and take it out, how hard is it to rebuild? 6500 hours and never been worked on.
Thanks, Randy
Orange Level Access Joined: 12 Sep 2009 Points: 19475 |
Why don't you think it's the torque limiter ??????
randy
Put a new limiter in 3 years ago.
Thought when i split it i would see whats up. Thought i would rebuild the power director and replace the limiter while it was apart.
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6471 |
Very rare for a pd to wear out, have you checked pressure??
randy
When the tractor is under load, pulling a field cultivator, and try to shift up, it hesitates to go into high range. Ground speed does not change and i went back to low range and no problems. I tried to shift it a couple of times and decided not to use any more.
My 8070 did the same thing and when i had the power director rebuilt it was fixed. I dont have a dealer close buy that is familar with the 8000 series, so i was wondering if i could do it myself. Thanks, Randy
Ron(AB)
Orange Level Joined: 27 Dec 2009 Location: Alberta Points: 943 |
The amount of time it takes is the big thing. If you are a full time farmer, do you have a couple weeks in your schedule to pull wrenches?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Cleaning and inspection of the gerotor pump (transmission pump) suction screen might reveal some brass filings from clutch discs, which would mean a split/teardown is in order.
randy
I will check the screen first. Thanks for the info!
I have time this summer, and have a spliting stand to do it.
Post Reply | |
