8050 Power Director jumping
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Power Director jumping
    Posted: 18 Jan 2025 at 4:12pm
8050 power director started acting up.  We were grinding feed the other day, and the tractor was getting bogged down while grinding.  We finished, and when we went to move the tractor, it kept switching to high on the PD.  It would then switch back to low, and bog down, then go to high, and then back to low, until we shut it off.
Started it back up today, and it keeps switching back and forth between low and high.
In my mind, I feel like this is an electrical problem, and the solenoid is jumping back and forth?  Do you think that I am on the right track? Or is it some other problem, like hydraulic?  Any tests that I could do to troubleshoot?
Thank you
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 7:54am
Wish I was there to witness what's going on. The transmission oil is FULL, right ?? Stab the dipstick more than once and look at BOTH sides of the dipstick to verify the oil level. Swing out the battery tray. Locate the high range solenoid on the Power Director valve which is pointed down. Disconnect the wires going to the solenoid's coil. This will insure it cannot shift to high range via the Power Director valve shifting mechanism.
Edited by DrAllis - 19 Jan 2025 at 8:00am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 8:17am
Hope it is the solenoid. I think many years ago we had failure of the center sealing ring on the clutch snout and it would bleed over and pressurize high range. It takes less pressure to engage high - as high engaged with low still on it bogged, then low kicked out but still was trying to engage. It did not shift up and down though. Doc might comment on the mechanical aspect..
Edited by tbran - 19 Jan 2025 at 8:17am
