8050 PD shift issue
Joe(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(IA) Quote  Post ReplyReply Direct Link To This Post Topic: 8050 PD shift issue
    Posted: 06 Jan 2019 at 7:40pm
I have a 8050 PD with less than 4000 hours and has been well cared for and maintained.  I have had it a few years and last year I started having problems with the tractor not wanting to shift up on the go.  If I hold the lever up on the steering column and clutch it real(half way down) quick a few times it will shift up.  Now that doesn't work.  I replaced the hand switch on the steering column plus the big fuse on the fuse block with no success.  Transmission and hydraulic fluid levels are fine.  Any thoughts out there??
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 11:02pm
The switch on the clutch pedal could cause that problem...if it malfunctions you will only be in low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 7:15am
Along with if anything related to the clutch pedal linkage under the instrument panel is dry and sticky, that will not allow the switch to be depressed and therefore no upshift. The clutch pedal has to come up 100% to trip that switch.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 7:20am
Adjust the switch above clutch pedal or clutch pedal spring is not pulling pedal up all the way up.      MACk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 11:14am
Ok thanks guys.  I will do some investigating!
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 11:55am
Are PD clutch run by a cable?..a new cable on my PS 8010 done wonders...old one was sticking and stretched...something else to check out
Edited by Michael V (NM) - 07 Jan 2019 at 11:56am
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 1:19pm
Adjust and or change your clutch cable.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 4:51pm
It was the switch.  Nut came loose on switch and no contact was being made by clutch.  The plunger moves freely in and out on the switch.  Still lubed it up and lined up the switch where when clutch fully depressed the plunger goes all the way in!  Clutch linkage and movement appears perfect.  Thanks guys!
This page was generated in 0.289 seconds.
