8050 overheating
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Topic: 8050 overheating
    Posted: 16 Jun 2010 at 8:28pm
TThis spring I had a fire in my 8050 from a birds nest over the manifold by the time I realized what was happening and got the panel off the fire was just about out. When I took the right side panel of a piece of foam came off with it. Doing field work since this s tractor will over heat more than normal  I think the foam panel go toasted I need a part # for it.
Morley
Farm stuff 8050,6690,175,F2,5050,WD
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 5:31pm
It looks like its only a strip of foam or something. It calls it a strip seal and its number is 70263405 if im right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 5:59pm
thanks
Morley
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 6:31pm
