8050 N7 engine swap
 Post Reply Post Reply Page  <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2019 at 10:40am
Peterson,
Hope it runs and works for a long time. That is a lot of work to custom fit a big engine into that tractor. Looking forward to your progress too.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2019 at 3:31pm
Oofda!! Love it!
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2019 at 6:59pm
Wanted to show you guys KINDA what its going to look like.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2019 at 8:43pm
Originally posted by exSW exSW wrote:
My 560D Farmall ran the Ag bagger without even breathing hard.
You probably didn't have the brake pressure at 1800 psi either?
1800 psi can bring a JD 7810 to its knees.
A little CQB never hurt anybody.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2019 at 10:09pm
"Can I borrow a tractor?" "Sure,take that one." Was the extent of my involvement in the operation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2019 at 5:23pm
Drilling axle mount holes, had to throw the side panel on again and get a picture! Lol
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2019 at 8:32pm
Is the intercooler going to fit inside the hood? or are you going to put on an HD11 intake manifold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2019 at 8:34pm
Hood will be widened out. Haven't decided how yet. But engine will be pretty much the same as a N7 combine engine.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2019 at 11:36pm
Peterson, That looks like factory.  Awesome job! Will it have a 7080 exhaust muffler sticking up out of the hood, along with a front vertical intake too? Or will you do a clean hood view, plumbing the exhaust over & up the right front corner of it's cab?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 12:55am
Thanks! It will either have a single 4 or 5 inch exhaust pipe. Everything will be packed under the hood for sure. 7080 air filter so no pre cleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 11:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 11:27am
Thats nice, but the 516 takes up a tad bit more room under the hood than the 426. Im going to have a hard time routing the air intake and exhaust now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 10:09pm
Sorry about no update in a while. Been busy with other stuff. I've decided to make a turbo wedge adapter to go from the T6 flange to a T4 and use a different turbo. The original was blowing oil out so instead of rebuild it, I figured I'll upgrade it. Using the wedge adapter allowed me to have the turbo pushed in far enough to clear the stock hood width. So I won't have to widen the hood at all. WOO-HOO! other side is a different story though. Will be working on that later. Got new oil drain and feed lines made for turbo and new longer oil cooler hoses too. More to come!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 7:36am
Nice job! If you wanted make another,, I'm wanting to fit a 3 lm turbo under the hood on a 190 Xt for pulling so I wouldn't need it till next June,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 7:42am
Thanks! It was a pain... it's also a divided spacer too. Welding in the wedges and using the pencil grinder to smooth it all out on the inside was lots of fun!! Haha. So Idk about making another one though.... lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 7:52am
Completely understand !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 7:57am
peterson,
 Thanks for the updates and pictures! I can see good progress. Your in a area I know nothing about! Very good fab work on the turbo mount!
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 8:45am
Cool. Really,really cool.
But I still think I'd try to section the 8000 hoods.
Edited by exSW - 03 Nov 2019 at 8:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 11:49pm
Hey guys, sorry I havent updated this thread on the 7095. Cant find a good easy photo hosting site so I've been uploading to our farm Facebook page. Here's the link, Peterson Farms Facebook Page
Had her on the dyno awhile ago and she is putting a easy 255Hp out. Have ran her on the chopper all first crop and now starting second, all I can say is WOW so much more "Oomph" than the 426. Dont have to really worry about slugs of hay going in to fast anymore, just powers right through them. Before with either the 8070 or 8050 one would have to quickly shut off the head before it sucked it all into the cutter head and bogged the engine way down.
Cant wait to get her all painted up this winter and maybe take her to a show or two! It sure is awesome!
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 7:02am
Cool project. It looks good and I bet it's a brute in performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 8:31am
Great AC project! Always good to see projects become reality. Looks like you’re enjoying it too. Thanks for sharing.
JC-WI View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 9:55am
Here is just one of Tyler Peterson's awesome pictures of his 7095...
https://www.allischalmers.com/forum/uploads/242/Petersons_tractor_7095_small.jpg
 Tyler, Did you get the noise taken care of or using ear plugs and muffs to deaden the headache causing drone? Don't see a muffler on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 10:19am
The 7000 front looks good with the 8000 cab!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 10:36am
Hey thanks!! And yes I did get a muffler on it, well really in it. I took a 4 inch piece of pipe and drilled a lot of 1/2" holes in it and then welded that pipe inside the 5 inch pipe. You can buy the stack internal mufflers but I wasn't going to pay the couple hundred bucks for the 4 inch pipe with a bunch of holes in it. Lol, so I made my own. Took the drone right out of it, still is loud but nothing unbearable.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 10:38am
I gotta say though the 8000 series has grown on me as far as looks, I've always preferred the looks of the 7000 series. IMO that is what the 8000 series should look like. Great job!
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 10:41am
Thanks for the awesome words guys! I appreciate it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 7:56pm
Hey guys we will be chopping either late tomorrow afternoon, and/or Sat**day. Anyone that wants to come check her out and listen to her is more than welcome to come!
