8050 lights
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: 8050 lights
    Posted: 03 Apr 2012 at 10:16pm
My 8050 has a short in the field lights. The flashers work and the flashers and road lights work but when you put the switch to the field (flood) position after a few seconds the circut breaker pops and the lights go out.
We unplugged the four center lights and the breaker still pops leading us to think it's wiring, but we've replaced the circut breaker and relay and tried a different light switch too.
It looks like the wires are routed up the right front cab post and I not sure where from there. I suspect a mouse has chewed a wire someplace. Any suggestions where to look, or if we're barking up the right tree?
AGCO My Allis Gleaner Company
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 10:25pm
Wiring problems are a royal pain in the keaster. Looks like you are headed in the right direction. Good luck.
Steve
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 10:47pm
my 7080 field lights (stadium lights) would work for awhile, then go out, after the switch cooled down (got so hot you couldn't touch it) they would come back on! replaced the switch and it's the same thing! pffft!
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 6:02am
If you unplug all of the lights on the circuit and unplug the harness before it goes up the cab post you can verify a short with an ohm meter. You should not have resistance from the wire to ground.
You will have to remove the roof to access the harness in the cab if it is shorted in the post or top of cab.
The universal answer to all questions is yes, how much do you want to spend?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 10:48am
It may be as easy as anything to just use the existing wires to pull new wires down through the post and be done with it.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 7:47pm
Removing the roof won't gain access to any wiring.  I found out the hard way on a hot day after removing all 18 Censored bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 10:11pm
The wires are in a loom going up the right post so I couldn't pull just the light wires. It looks like above the lights there is some access panels? We found out the hard way there isn't access after the roof comes off. LOL We'll get back to it this weekend. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 10:33pm
There are 2 blue wires going up the post.  There is a plug at the top I had to put a splice in one to bypass the plug.
