8050 help with front tire size
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: 8050 help with front tire size
    Posted: 19 Feb 2010 at 9:35am
I am replacing the front tires on my 8050 they are 14.9 x 28 bias. The replacement size is 380/85/28 radial metric. I have the new radial tires sitting beside the old bias and the new ones look much bigger, they are unmounted at this time. Do I have the correct size? I have 20.8 x 38 radials on the back. The brand of the new tires is Continental Thanks in advance. rieg from swoh
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 9:51am
380 divided by 25.4 is 14.9 if that helps.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 9:56am
that tire should measure 53.5 inches tall and 14.9 inches wide
This page was generated in 0.152 seconds.
