8050 fwa steering cylinder end
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: 8050 fwa steering cylinder end
    Posted: 28 Mar 2019 at 9:37pm
I need to cut off and replace the wheel end of the steering cylinder. I believe it has been replaced before with a swedged ball end. The cylinder needs rebuilt and I have the kit but I want to replace the end first. Does anyone here know where I can get one with the correct size hole. The one that is on there is to sloppy to leave on. Any suggestions would be great thanks.
rieg
670denny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 670denny Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 8:06am
I have to look..may have a old cyl here with a end on it..but they do have the ball socket type end that is replaceable if the hole in end isn't dlopped out..let me know
Denny
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 8:17am
Thanks Denny let me know what you find yours may be better to rebuild than mine. The one I have has had the original end replaced. I have repaired my other 8000s with ACGO parts but this one is different.
rieg
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 11:10pm
There was a change made in later serial numbers to a different attachment to the knuckle. My 8070 is a
Little wallowed. I replaced the ball and put a piece of nylon under to keep it from dropping down. When I get a chance I will turn a bushing and bore the cylinder mount out. Then press and weld it back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 670denny Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 4:09pm
haven forgot you...just been busy and rain
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 9:22pm
670 denny did you find an end to the 8000 fwa steering cylinder.
rieg
