8050 Fuel line diameter |
Post Reply |
Johnwilson_osf
Orange Level Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 928 |
Posted: 4 hours 22 minutes ago at 6:33pm |
Hello Orange Family,
I was discing with the 8050 tonight, when a huge cloud of white smoke came billowing out from under the hood. Managed to find a hole in the number 5 injector line kist below the ehxaust manifold. Hot manifold, and good flowing fuel, = lots of white smoke. Now I need to repair. It was getting dark, so I will work on it in the light tomorrow. I am thinking of bending my own fuel line to replace this one. It has been a while since I had one of these apart. I forget if the flare at the end is single, or double. I know I have some new rubber washers that seal the line under the threaded cap. In addition to the type of flare, does anyone know the diameter of the line? Can I Get fuel or transmission line from the store to work? In case it matters, it is the set up where the lines all go straight up from the pump, then cross over and above the exhaust manifold, not the other one. Thank you, John
Edited by Johnwilson_osf - 4 hours 16 minutes ago at 6:39pm |
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8154 |
Isn't it just a special ferrule under the nut?
Post Reply | |
