8050 clutch/trans brake
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: 8050 clutch/trans brake
    Posted: 15 Oct 2010 at 9:28pm
Been driving the power shift 8050 for Dad this fall and this is really annoying, push on the clutch pedal and as soon as the clutch disengages, the trans brake slams the tractor to a stop. I have tried pushing the pedal in just a half inch at a time and as soon as the clutch releases the brake is activated. Is there a simple ajustment that can be made? Is the trans brake applied by an electrical switch at the pedal or at the end of the clutch cable? It can't be good on the transmission.
Thanks
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 10:11pm
Under the dashboard above the clutch pedal is an adjustment bolt that needs to be adjusted.....takes a 3/4" wrench I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 5:16am
Thanks very much, I'm headed out now to disc stalks. I'll see what I can do with it before I leave.
Leon B MO
