8050 clutch/trans brake |
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2135 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Oct 2010 at 9:28pm |
Been driving the power shift 8050 for Dad this fall and this is really annoying, push on the clutch pedal and as soon as the clutch disengages, the trans brake slams the tractor to a stop. I have tried pushing the pedal in just a half inch at a time and as soon as the clutch releases the brake is activated. Is there a simple ajustment that can be made? Is the trans brake applied by an electrical switch at the pedal or at the end of the clutch cable? It can't be good on the transmission. Thanks
Leon B MO
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 20980 |
Under the dashboard above the clutch pedal is an adjustment bolt that needs to be adjusted.....takes a 3/4" wrench I think. |
Thanks very much, I'm headed out now to disc stalks. I'll see what I can do with it before I leave. Leon B MO |
