8050 Allis
Cummins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cummins Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Allis
    Posted: 10 Mar 2010 at 5:15pm
Do you guys know how to turn an injection pump up on an 8050 Allis? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 7:07am
Really shouldn't be done without a dyno to verify the beginning and ending results. Remove the four bolts holding on the pump governor cover with a 7/16" socket. Locate the horizontal adjusting screw under the cover. Loosen the jam nut (7/16" open end wrench) and turn the screw with a flat blade svrewdriver "out" (counter-clockwise)) 1/2 turn and reset the jam nut. Re-install the cover.
