8030 ? |
SteveMaskey(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wellsville, MO Points: 617 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Apr 2025 at 6:16am |
I have oil leaking around the pinion shaft on my 8030 FWA how hard is it to replace the seal?
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2390 |
Remove the drive shaft and yoke from the input shaft. Pop the tin dust cover off and the seal is right there. I drill a hole in the seal and pull it out with a screw. Check your bearing play while there.
Thanks Lynn for the info
