8030 ?
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Topic: 8030 ?
    Posted: 25 Apr 2025 at 6:16am
I have oil leaking around the pinion shaft on my 8030 FWA how hard is it to replace the seal?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 7:05am
Remove the drive shaft and yoke from the input shaft. Pop the tin dust cover off and the seal is right there. I drill a hole in the seal and pull it out with a screw. Check your bearing play while there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 7:10am
Thanks Lynn for the info
