8030 troubles
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Topic: 8030 troubles
    Posted: 25 Oct 2024 at 4:58pm
I believe this is the FWA valve. It is leaking oil out of the solenoid. Are these repairable? Parts book says 70272654 is seal kit for solenoid. Is it possible to remove the solenoid without removing the valve body. This is a 8030 with power director transmission serial F2263
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 7:24pm
I think there is an o-ring under it?
What did you find?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 7:44pm
Yes, the thin nut on top holds the coil on. Nothing to leak with the coil. The stem that the coil goes on can then be unscrewed from the valve body , if that's where it is leaking. Just an O-ring to seal the stem assembly to the valve body. Careful, there's a fair amount of pieces in the stem. Don't lose them.
rmullican View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 7:34am
I put on oring on mine last week. I believe it was less than a dollar for the part and about 30 minutes to take coil of solenoid, clean, pull solenoid and replace oring. The hard part on mine was the aux fuel tank with 60 gallon fuel.
170 W/FEL, 7010 PD, 8030 FWA PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 6:20pm
I took the thin nut off but can’t get the tin cap to come off. Tried tapping on it with a hammer and screwdriver but it won't budge, and I don’t want to break anything. Would it be ok to spray penetrating oil on it? The stim is very loose so I suspect that is where it is leaking. Thanks for all the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 6:29pm
I soaked mine with PB Blaster, there is a metal sleeve between the nut and the metal cover for the coil. A little elbow grease and it should come apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 8:25am
If the stem is loose, you might try tightening it and see if it stops the leak.
This page was generated in 0.363 seconds.
