8030 troubles
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Topic: 8030 troubles
    Posted: 12 Mar 2024 at 9:09pm
When I turn the key on the headlights come on. It is the red wire on the ignition switch that splits. One goes to the ether injector and one goes somewhere else that is feeding them when I unhooked it they went out. I figured a mouse might have chewed some wires but can find no evidence of that. Where would someone look for the problem hate to start tearing the wiring harness apart
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2024 at 8:07am
Theres a wiring diagram in the onwers manual that should help. In my mind it would have to be the light switch or wires have rubbed together
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2024 at 3:19pm
Someone might have carved up your wiring under the dash.  The service manual has the wiring diagram.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2024 at 7:19pm
I finally found the problem. Where the wiring harness y’s at the rear of the block two wires got together. The insulation had failed even though it still had the factory wrapping
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2024 at 8:27am
Years and hours take their toll.....
