8030 pto issue
rmullican View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Topic: 8030 pto issue
    Posted: 21 Apr 2024 at 6:48am
I flipped pto from 1000 to 540 on a new to me 8030 and found the 540 shaft face and mounting holes have damage. Gaulding around mounting face, a broken tap in one of the holes and gaulding build up inside mounting holes.
I have not done any pto work with tractor yet and have no idea how old this issue is.
Currently removing gauld buildup and attempting to clean up and chase the threads in bolt holes.
I would assume the 540 shaft walked out and came in contact with pto stub
Is there any way to check pto shafts end play without draining oil and dropping rear plate?
170 W/FEL, 7010 PD, 8030 FWA PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2024 at 8:48am
Bolt the Dual PTO shaft back on using ALL the bolts and grab the end of the PTO shaft and push/pull/up/down to check for excessive endplay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 5:29am
PTO seems secure, I'll be testing with 540 and 1000 implements before it gets put into any heavy service.
Thanks for the info
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 9:35am
We have seen this a couple of time due to customer flipping the shaft and USING THE SAME HOLES - they said "some of the holes didn't line up  so we 'wallowed the holes' a tad.  Then the damn thing got hot." Duh,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 10:39am
Awe wow- Tbran ,, very interesting
