8030 Power Steering Valve
jstewart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jstewart Quote  Post ReplyReply Direct Link To This Post Topic: 8030 Power Steering Valve
    Posted: 20 Mar 2012 at 7:04am
The valve is leaking out the top end. Has anyone rebuilt one of these? Is it a fairly straight forward process? I've not found an aftermarket valve so I'm guessing they're not available?
Thanks for any help,
Jared (MO)
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 7:45am
Take tke sparol ring out of top then pry the center cover out. Replace the seals just like they came out. Replace the oring on the relief valve. Measure how deep the the screw is in, back it out replace the oring then screw back in the same depth.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jstewart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 8:28am
Thanks Mack. I'll see if I can order a seal set and give it a try.
Jared
