8030 muffler delete |
thumbfarmer ![]() Bronze Level ![]() Joined: 12 May 2017 Location: MI Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 12 May 2017 at 7:26am |
Hey I'm new to forum, and have a question about a muffler delete on an 8030. Anyone try it? Any hp gain? Engine run cooler? How much louder is it? Thanks!
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12225 |
Huh?!
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
IM sure he's thinking chrome straight pipe
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Thomure 800 527 9954 sells muffler eliminator exhaust kits - with aspirator tubes. There is almost no restriction in the OEM muffler at field settings - you will not see any measurable difference - you will hear the engine respond w/o the muffler - have a customer using one - it is not like a straight pipe , but louder than oem muffler.
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2191 |
I have the Thomure eliminator in an 8050, performance no difference. Inside the cab it sounds no different than the factory muffler but from the outside it sounds louder and really bellows with factory pipe though the hood. I'll put it on the other 8050 & 8070 when those mufflers rot out.
Leon B |
mark-east-tn ![]() Orange Level ![]() ![]() Joined: 06 Oct 2009 Location: Rutledge Tn Points: 761 |
What do those kits cost ? Ive got a 8010 Ive thought about doing muffler delete .
8010 is probably different from the 8030, 301-426. Call the number above, asking is free.
Leon B |
bradley6874 ![]() Orange Level ![]() Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
what leon said is exactly correct I belive it does eliminate some heat under the hoood . when you price a new muffler like most of us you will be calling for an eliminator once you pick yorself up
Getting ready to eliminate the muffler on my 7020 for more visibility. I found a 4" x 12" resonator that will fit under the hood and plan to run a 3.5" pipe from there up, lining it up with the pre-cleaner pipe. I'm hoping it wont increase the noise if I get it above the cab.
Leon B Edited by Leon B MO - 13 May 2017 at 10:50am |
