8030 MFD knuckle pin removal
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Topic: 8030 MFD knuckle pin removal
    Posted: 25 Jun 2023 at 6:16pm
Before I start making a mess, is there a trick to pulling the king pins out of the knuckle?
Thanks!
Matt
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 6:26pm
There is a puller for those. Threads in the grease zerk and pulls the pin out.
ryan
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 6:30pm
Take the grease fitting out. Its metric. Determine the size and thread pitch
Get a threaded rod that size and cut a piecce long enough to go through a socket that is bigger than the pin so that it is against the knuckle. Good grade threaded rod is better. With a nut and washers on the rod screwed into the pin the socket gives you a hollw place to pull the pin out. May have to use a little heat on thee knuckle
Ive got to replace mine too
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 8:15pm
Fantastic! Thank you all!
Hopefully she's not rusted too bad
Matt
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 12:24am
I think there is another way...take out the grease nipple, then weld a nut over top (3/8- 1/2"), thread a rod into it, put a piece of pipe over it then a thick washer or two, then a nut, and tighten it and it pulls upward.
Grind off the welds when its out.
Been a while since I've done it but there was pics on here a few years back.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 5:41am
Chances are good the pin will be worn and need replacement anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 7:16pm
Pin internal threads for the puller are M10-1.0.. cut a bolt and welded a 1/2" fine thread to it. Worked good, kept stacking 1 1/2" washers under the socket as it came out. Pins actually in good shape. Bearing was screwed, cage half gone. Flushed the housing out can't see any metal anymore.
Will change the other side now that I'm all set up to do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 7:23pm
Parts inside the axle rusted up a bit, tractor sat a lot before I got it. I suspect that helped take the bearing out.
I can see a little bit of the pinion through the drain hole and it doesn't look too great. No hardness flaking off that I can see but quite worn..
Has anyone rebuilt one of these recently? I'd rather pull it in the off season and rebuild it before it's a problem
Matt
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 7:47pm
Uhh, I looked up the parts cost from an Agco dealer.
4 pins and 4 bushings/bearings. About $1600.
Aerospace prices.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 9:35pm
Pins,bearing, seals are gonna set you back about 2500-3000 for the whole front. We just did ours this spring. Ring and pinion from heitman is brand new and last I knew wanted about $4500
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 7:43am
Is Heitman the only source for a ring and pinion? I haven't checked AGCO myself.
It's all functional now, knuckle pins and bearings in good shape just the axle seals and bearings we're bad.
But if this stuff is hard to get I'll start making a parts pile for the inevitable differential rebuild in advance
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 8:00am
Heitman is only place I know of. Hasn’t been available from agco for years
ryan
