8030 FWA |
Post Reply |
Oldred
Bronze Level Joined: 21 May 2010 Location: Bluffton,AB,Can Points: 148 |
Posted: 15 Jan 2016 at 11:06am |
Anyone have a good source for a complete front end rebuild kit ? Not the differential just the outer bushings/bearings/seals/Ujoints etc ? Just priced out at Agco and had a small heart failure LOL.
Thanks Mark |
Orange Level Access Joined: 12 Sep 2009 Points: 19499 |
I can't imagine being able to find ANY parts for those FWA axles other than an AGCO dealership. The axle was made by a company called SIGE from Europe and all their parts are unique.
MACK
Do I remember right that Sige is owned by Deutz? MACK
Daehler
Orange Level Access Joined: 23 Nov 2010 Location: Lexington MO Points: 1152 |
I spent around 14 grand on my 8070 it was high but as long a it gets greased and taken care of it should last another 10000 hours.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
Hurst
Orange Level Joined: 11 Sep 2009 Location: Midway, Ky Points: 1201 |
I'm not sure, but look up a Moog 486 U-Joint. It states it is a 4.1 inch across u-joint that is for Deutz and Allis front steer axles made by SIGE. I couldn't find a whole lot more information on the internet, but if you can find a good parts guy with a moog catalog, that should be more helpful. It looks like everywhere is about 2 weeks lead time on them. This might be the part AGCO is selling? It can be found for around $160 +/- on the internet. If it fits, that savings would add up after 4 of them.
Amazon can get them: This place is where I got the 4.1 inch across dimension: This website lists applications for Allis and Deutz steer Sige axles: Edited by Hurst - 15 Jan 2016 at 9:40pm |
1979 Allis Chalmers 7000
5800 Hours |
427435
Orange Level Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
I don't know about today, but they were an independent company back when we sourced the axle from them. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
ivan
Silver Level Joined: 12 Sep 2009 Location: NE Michigan Points: 319 |
we can help what do you need 989-379-2721
Allis 8050
Silver Level Joined: 29 Dec 2014 Location: Western PA Points: 52 |
sige is now owned by spicer
AC C, D-15,D-15II,ONE-SEVENTY,185,200,7010,8010,8030,8050 AGCO LT90a, AGCO RT130 and GLEANER R55
Oldred
Thanks for replies guys,
Currently Dana/Spicer own SIGE and they are looking for a possible kit which is probably not available. I am located in Alberta Canada so right now our exchange rate on Agco parts coming from the US is really poor. If I would have known I needed a rebuild 1 year ago it would have been a smaller pill to swallow so to speak LOL. Actually the Agco U-joints are not that bad at $419Can/293USD per side complete. Its just the rest of the seals bearings/bushings etc that add up. Thx Mark |
Northern Hoser
Bronze Level Joined: 19 Feb 2020 Location: Canada Points: 101 |
Just gonna bump this...
Has anyone tried to see if the Moog 486 fits the Sige FWA axle? Matt |
Unit3
Orange Level Joined: 17 Oct 2009 Location: NC Iowa Points: 5497 |
I might be way off on this, but did John Deere and Allis Chalmers both use the same company for their front ends.
PeteMN
Bronze Level Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 192 |
We used a Moog 486 on an 8050 FWD. The last one came from a regional truck drive line company, I think they found one in a warehouse in Nebraska. Years ago we ordered one thru NAPA and it showed as a Precision Brand U Joint, it was about $100 cheaper than Agco. I think Precision is owned by Moog now. I'm a little surprised how hard they are to come by these days, especially compared to truck u joints. A mechanic friend of ours said he thought the aftermarket u joint fit a little loose in the end cap mount, but we didn't notice any play. The mounting bolts for the U Joint are even crazier in price, they are a hex head bolt w/metric fine threads, but in order to have enough clearance they went with a smaller than std hex head. At one time they cost $7 each, last time I checked they wanted $28 each. A std metric hex head bolt with that thread cost $1 each. I scrounged a couple used ones from a helpful dealer's salvage axle the last time we worked on our tractor.
8070nc
Silver Level Access Joined: 21 Mar 2019 Location: North Carolina Points: 401 |
Could the $1 dollar bolt head be turned enough to work |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Northern Hoser
Good to know, Thanks. Mine aren't that bad but if they're getting scarce I better start sourcing them now.
Matt |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7980 |
I'm not familiar with these fronts but could a allen head style be used? Probably a clearance problem some where.....
PeteMN
Its been a while since we worked on ours, I'm not sure you can get at an allen head bolt. I ordered std head metric bolts from Tacoma so we can modify them if we need to. There were a few more on a dealer's burned salvage unit, too, but would have had to heat them to get them to turn out(maybe they'd come out).
Post Reply | |
