8030 FWA axle leak |
Northern Hoser ![]() Bronze Level ![]() Joined: 19 Feb 2020 Location: Canada Points: 123 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Jun 2023 at 7:54pm |
Hi all, axle stub leaking on the front as seen in the pic, axle has some movement so guessing bearing is on the way out ...which bearing and seal is it in the diagram?
I'd like to preorder the parts but scratching my head as to which ones they are Thanks ![]() ![]() |
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 789 |
16 is the bearing. 17 is the “housing”. 18-19 are seals and 20 is the o ring for the bearing housing
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
Awesome thanks, does that bearing housing come out with the axle? Looks like it's got a clip on the inside
Matt |
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2415 |
It will if you remove the screw #13.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Are you sure your bearing is going out? My 8050 axle was leaking someone suggested I clean the breather and I did it doesn’t puke anymore.
Thanks for the replies, I'll look at the breather again, I put a new O-Ring on it last fall could be clogged up I suppose, thanks for the suggestion.
Planting all done in these parts so have a bit of down time to get some work done on it; getting the air conditioning up and running shortly ![]() Matt |
