8010 w/Cummins: |
Codger
Topic: 8010 w/Cummins:Posted: 21 Nov 2023 at 6:16am |
This is the 8010 I've posted about in the past. It was sold here new, ultimately traded back in for another new tractor, resold again eventually being repowered with the Cummins engine. It was then brought in for some type of hydraulic problem that was impact related with a tree stump IIRC. A lot of money was expended repairing this damage including a new main pump and used set of hardlines/pipes which were bent up and unable to seal. The owner a couple of years later traded it back in for a new Massey-Ferguson tractor, and this one set to an implement dealer 175 miles or so distant on a dealer trade.
I was surprised the tractor is back. Nothing wrong with it; just in for routine service and it runs very well. Turns out the owner's neighbor wanted to purchase the tractor but didn't decide quick enough he wanted it. The current owner purchased it and traded in an older Ford tractor at this distant implement dealer so it is back in this area. |
That's All Folks!
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3580 |
Posted: 21 Nov 2023 at 11:20am |
Thanks for sharing it's storyline. It is still looking good & earning its keep. When you say cummins, I'm guessing a 5.9 12v rotory or P-pump? If so, whats it's hp setting? Did you do the cummins repower?
Edited by AC7060IL - 21 Nov 2023 at 11:26am |
Posted: 21 Nov 2023 at 12:44pm |
The Cummins 5.9/12Valve that we put in my brothers 7020 had the "VE" pump on it. With the high idle at 2500 RPM, pulled down to 2300 rated speed for the 7020 chassis, we had 135 HP. Perfect. When I pulled it on down to 2000 RPM, I got 180 HP !!! Tremendous torque build up !! A really nice 450 bushel corn hauler in 6th gear PST any hill we have and no need to ever downshift.
Codger
Posted: 21 Nov 2023 at 1:59pm |
I did nothing to or with the tractor at all. I think one of the prior owner's did the repower but I will attempt to find out it's current settings as know the original owner's and second owner's families well.
That's All Folks!
DougG
Posted: 21 Nov 2023 at 5:49pm |
Sure hope its not a 6.7 L, - geesh we got one of those in a crane at work and that sucker drinks the fuel-- bad
Codger
Posted: 21 Nov 2023 at 9:49pm |
Here is a link back to my original postings last year:
That's All Folks!
AC7060IL
Posted: 22 Nov 2023 at 1:18pm |
Here is a conglomeration of specs that I found online per some independent websites. A few sites listed Dodge Ram's hp/torque specs versus years, pumps,
turbos, etc... Other site's listing is more generic (cylinder bore/piston skirt diameter, bolt torques, etc..). Length 40.0" Width 24.9" Height 37.9" Weight 1000-1100 lbs Compression Ratio 17.0:1 - 17.5:1 Bore/stroke 4.02" X 4.72" Main bearings 7 Firing order 1-5-3-6-2-4 Cylinder bore inner diameter: 102.116 mm (4.0203 in) Piston skirt diameter 101.880-101.823 mm (4.011-4.0088 in) Piston ring end gap: First 0.400-0.700 mm (0.0157-0.0276 in) Second 0.250-0.550 mm (0.0098-0.0217 in) Oil 0.250-0.550 mm (0.0098-0.0217 in) Piston pin outer diameter 39.990 mm (1.5744 in) Connecting rod small end diameter (standard): 40.042 mm (1.5765 in) Crankshaft main journal diameter: 82.962 mm (3.2662 in) Crankpin diameter: 68.962 mm (2.715 in) 1989-1993 160 hp @ 2,500 RPM 400 lb-ft @ 1,600 RPM Bosch VPE44 Rotary, Holset H1C, non intercooled(89'-91') (91.5'-93) waste gated version Holset H1C, air-to-air intercooled. A727 3 speed heavier-duty version automatic transmission. Manual 5 speed was offered, but hp settings remain @ 160hp. 1994-1995 160 hp @ 2,500 RPM (auto) 401 lb-ft @ 1,600 RPM (auto)(Bosch VP7100) 175 hp @ 2,600 RPM (manual) 420 lb-ft @ 1,500 RPM (manual) Holset WH1C, air-to-air intercooled 47RH auto & NV4500 5-Speed manual Piston fuel-bowl new design provided better swirl and improve overall combustion quality and made of highly temperature-resistant aluminum alloy. 1996-1998 180 hp @ 2 ,700 RPM (auto) 420 lb-ft @ 1,500 RPM (auto) (Bosch VP7100) 215 hp @ 2,700 RPM (manual)440 lb-ft @ 1,500 RPM (manual) Holset HX35W or HX35, air-to-air intercooled(holds 40psi boost). Main bearing cap tightening procedure and torque specs: Step 1: 60 Nm; 6.0 kg·m; 45 ft·lb Step 2: 119 Nm; 12.0 kg·m; 88 ft·lb Step 3: 176 Nm; 18.0 kg·m; 129 ft·lb After securing bearing cap bolts, make sure crankshaft turns smoothly by hand. Connecting rod bearing bolts Step 1: 35 Nm; 3.5 kg·m; 26 ft·lb Step 2: 70 Nm; 7.0 kg·m; 51 ft·lb Step 3: 100 Nm; 10.0 kg·m; 73 ft·lb Flywheel fixing bolts 137 Nm; 14.0 kg·m; 101 ft·lb Head tightening procedure and torque specs: Step 1: 90 Nm; 9.0 kg·m; 66 ft·lb Step 2: 120 Nm; 12.0 kg·m; 89 ft·lb Step 3: Turn all bolts 90° Valve clearance (Cold)
Intake valve 0.25 mm (0.010 in) Exhaust valve 0.51 mm (0.020 in) Edited by AC7060IL - 22 Nov 2023 at 1:27pm |
Posted: 22 Nov 2023 at 4:26pm |
Brother is very happy with everything about the Cummins 5.9 engine performance. Starting in cold temps is the first thing one notices....it just starts as soon as you hit the push button. Power and torque are in the 426 performance area. Fuel economy he doesn't really keep track of, but I'm going to say pulling his 12-row White planter, it uses no more fuel than the 7020/301-TI did because it probably doesn't hardly use 100 HP even on our worst hills and the more modern engine is more fuel efficient to begin with. No regrets.
Codger
Posted: 15 Dec 2023 at 8:31pm |
This tractor is back in with a destroyed transmission. Several gears are missing teeth as a bearing came apart and apparently rode around for a spell. Tractor is split and mechanics are tearing into it now but it's pretty much carnage in places, and untouched in others. Front driving gear and it's corresponding countershaft gear each have teeth knocked out so must have been violent.
Really don't know much more than that but going to tear it apart fully, price parts and labor, then compare to used replacement, or reman exchange.
That's All Folks!
Posted: 16 Dec 2023 at 12:03am |
The 8010 Power Shift tranny has one planetary that was cheapened up compared to the 8030 and up models. They felt it was more than adequate for 110 HP . The Cummins has probably overpowered that area and she ate her pigs !!
Codger
Posted: 16 Dec 2023 at 7:03am |
Hope to know more in the upcoming week. So far, it looks bad however. Never been into a tractor transmission myself but have rebuilt several light and heavy duty manuals over the years. They have the books and were ascertaining how it comes apart when I left. One of the guys bumped a set of snap ring pliers setting on the case and they disappeared between the countershaft and gear case. My arms are small enough to get inside there and man is there a lot metal pieces where they shouldn't be..... That Cummins engine was originally a low power variant from an FL-60 Freightliner truck. The tag has 152hp stamped into it, but it's been "turned up" in power I'm told. I still see the original owner every now and then and will ask where it's calibrated at now.
That's All Folks!
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2427 |
Posted: 16 Dec 2023 at 9:21am |
The correct service manual and the special power shift tools will make the job easier. There should be a decent supply of used parts available, and the heavier pieces should work.
