8010 trans/ rearend oil dipstick |
ac45
Topic: 8010 trans/ rearend oil dipstickPosted: 19 Apr 2010 at 9:31am |
On my newly acquired 8010 the dipstick for the rearend is missing, alm0st like it has broken off, The cap etc is the same and original. This is on a powershift tractor. IS this the same as what would be on my 7060 PD as far as fluid level, Can i just use the 7060 dip stick to check it? Is it ok to use universal fluid in this rearend/ transmission??
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 19 Apr 2010 at 10:53am |
No dipstick,I think you will find sight bulbs down on left side.
rieg
Posted: 19 Apr 2010 at 11:29am |
There should be a dip stick for the power shift above and to the left of the rear end fill port. the levels are different for FWA it will be marked on the stick.
rieg
