8010 re-power
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 8010 re-power
    Posted: 29 Jan 2024 at 9:47am
This is probably going to sound like a another broken record but l did spend most of yesterday afternoon reading past post & researching this, but l,m thinking about put a 426 in my 8010 awd. Main concern is bell house area, it looks like flywheel, torque limiter & pieces except for the cluch disc are different, rad & hoses, exhaust< air intake and a few other things. Agco parts show different part # between 8030 74035834 and a 7030 74028149 flywheel ?   Will a gleaner 426 eng oil pan clear the fr diff in a 8010 ? Thanks Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 12:56pm
Why wouldn't the 426 pan fit the 8010 chassis? Isn't it the same throughout the 8000 series?
Dry creek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dry creek Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2024 at 5:48pm
I put a 7030 engine in my 2wd powershift 8010 2 yrs ago,had to change flywheel, got one from countryside tractor,make new hole in hood for exhaust,tweak radiator hoses a little.
Added a fuel shut off cable,reused throttle cable.
I didn't need a working a/c,as it is my feed mixing tractor
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2024 at 7:50am
I think you would be happier with a 5.9 cummins swap. We did the swap into our 7020 powershift and the tractor is pretty awesome.  Make sure its a 5.9 out of a commercial application, not a truck engine.  Ours came out of a gradall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2024 at 8:29am
Thanks guys for the info, I wanted to go 5.9 but tuff finding a 12 valve here in Ontario, I priced a adapter witch was around $3000.00 us then almost another 40% because we live north of the border, then throw in a flywheel & a few more pieces it looked like it could get pricey, Thanks Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2024 at 9:03am
8010 a Power Director tranny I hope ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2024 at 9:07am
No Doc its a PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2024 at 9:22am
8010 PST's have a lighter duty transmission than 8030-70's, so beware that a HP increase and more ballast isn't probably a good idea. If everything heavy is done in 6th gear, shouldn't be a problem as that is direct drive.
Edited by DrAllis - 01 Feb 2024 at 9:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2024 at 9:37am
Ya Doc I hear ya and 3rd & 4th in low range are the most use gears on our farm with this tractor, a 426 mite pull the 1350 cultivator in 6th
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2024 at 6:00pm
If I was you I'd fix the 301, or put a 24 valve 5.9 in it.  No one seems to want them, and the VP44 fuel pump has an excellent governor in it.  I understand the expense of the conversion completely, but I will guarantee your fuel consumption will drop and it will start on the first revolution of the crank when its -10 C.  No 301 I ever saw starts as well,  for some reason every 8010 I have been around did not want to start worth a crap, yet my 200 fires right up in same conditions, that kind of confuses me....you put a 426 in it and it going to use considerably more fuel.
What is wrong with the 301 in it?
CDN 400 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2024 at 6:50pm
There is an amish guy one road north of me who usually has lots of 5.9's for sale or whatever your looking for. Last time I was there he had 2 brand new 19liter cummins sitting there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 2:37am
Curious how you could put a 5.9 with a VP 44 in a tractor? Arent they computer controlled?
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 7:15am
The ECM are bolted to the block  the dimensions are the same as a 12 valve.  Wiring is easy can be found all over the internet
Amos View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 7:16am
Hey 400, would that be Noah???
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 11:07am
Yep. Can almost see his place from mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 12:52pm
I gotcha- thanks Amos- never thought of that
This page was generated in 0.040 seconds.
