8010 remote hydraulic couplers
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 8010 remote hydraulic couplers
    Posted: 16 hours 13 minutes ago at 4:58pm
l have quite a time not destroying the O-rings in the remote couplers, in a seal kit that l got from AGCO (#70264224) there is 2 rubber o-rings & 2 white scarf cut plastic rings. l figured the white scarf cut rings would be a backing ring & would act as a guide for the pioneer hose fitting to enter the coupler and protect rubber rings, but there's not enuff room for both rings. Can someone tell me what I,m missing here ? Thanks Dave
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 54 minutes ago at 8:17pm
Just went through this also on one of our 7060's with the Bruining ,(AC), hydraulic couplers. It was a pita getting both the o-ring and back up ring seated properly. The backup ring is needed and I trimmed a little off each end to get it placed. The back up ring goes on the inside of the o-ring. It appears to me that these are a little different from the originals, once installed no leaks. Good Luck , Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 21 minutes ago at 6:50am
Thanks Mike, maybe with out that back up ring not there it allows that rubber ring to roll over a bit and gets pinched on the land wall, Dave
