8010 remote hydraulic couplers |
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 258 |
Topic: 8010 remote hydraulic couplersPosted: 5 hours 21 minutes ago at 4:58pm |
l have quite a time not destroying the O-rings in the remote couplers, in a seal kit that l got from AGCO (#70264224) there is 2 rubber o-rings & 2 white scarf cut plastic rings. l figured the white scarf cut rings would be a backing ring & would act as a guide for the pioneer hose fitting to enter the coupler and protect rubber rings, but there's not enuff room for both rings. Can someone tell me what I,m missing here ? Thanks Dave
Mike Kroupa
Joined: 02 Oct 2009 Location: pierce, ne Points: 338 |
Posted: 2 hours 2 minutes ago at 8:17pm |
Just went through this also on one of our 7060's with the Bruining ,(AC), hydraulic couplers. It was a pita getting both the o-ring and back up ring seated properly. The backup ring is needed and I trimmed a little off each end to get it placed. The back up ring goes on the inside of the o-ring. It appears to me that these are a little different from the originals, once installed no leaks. Good Luck , Mike
