8010 PTO oil leak
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 8010 PTO oil leak
    Posted: 08 Apr 2024 at 7:49am
Have a slow fluid leak at the pto BRAKE cover, do l need to remove the bottom plate to catch parts before l remove the brake cover or can l just remove the rear brake cover? Thanks Dave
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 7:30am
No. If you're just removing the cover,have the O rings on hand and do it quickly. You won't even lose much oil that way. Be careful with the little steel sealing ring on the end of the shaft.
