8010 PTO oil leak |
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 261 |
Topic: 8010 PTO oil leakPosted: 08 Apr 2024 at 7:49am |
Have a slow fluid leak at the pto BRAKE cover, do l need to remove the bottom plate to catch parts before l remove the brake cover or can l just remove the rear brake cover? Thanks Dave
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2484 |
Posted: 09 Apr 2024 at 7:30am |
No. If you're just removing the cover,have the O rings on hand and do it quickly. You won't even lose much oil that way. Be careful with the little steel sealing ring on the end of the shaft.
