8010 power shift oil leak |
Post Reply |
automaticdave
Silver Level Joined: 20 Jan 2011 Location: Granton, ON Points: 226 |
Posted: 10 Jan 2024 at 3:16pm |
Is it very common for the detent shaft seal to leak fluid, there is not much rubber on that metal clad seal for oil to get past it & the shaft? Thanks Dave
JTA FARMS
Bronze Level Joined: 05 Dec 2021 Location: Pennsylvania Points: 11 |
If I remember correctly there is enough room in the valve body case that you can install two seals together and still get shifter arm on. Did that to a 8030 once and it solved the leak.
Post Reply | |
