8010 power shift oil leak
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 8010 power shift oil leak
    Posted: 10 Jan 2024 at 3:16pm
Is it very common for the detent shaft seal to leak fluid, there is not much rubber on that metal clad seal for oil to get past it & the shaft? Thanks Dave
JTA FARMS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTA FARMS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 5:30pm
If I remember correctly there is enough room in the valve body case that you can install two seals together and still get shifter arm on. Did that to a 8030 once and it solved the leak.
