8010 lights???
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: 8010 lights???
    Posted: 07 Apr 2010 at 2:18pm
got up and replaced an old stadium with a new universal, pluged in- al the back on and after a few minutes i was about to climbe down and the entire back went out
i have fuses- do i need to pick up anything on the way to the shop? does this have just fuses or a breaker? the fronts still work- the tractor was not running when i did this
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 7:44pm
Some 8010 have fuses, some have breakers (early serial # vs late).  Check your operators book for schematic of wiring and remove the panel directly under the steering wheel.  May have a weak breaker.
The innovators offer what others will imitate.
This page was generated in 0.095 seconds.
