8010 Hydraulic Pump Leak
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 8010 Hydraulic Pump Leak
    Posted: 04 Apr 2024 at 7:36am
I,ve sprayed the pump down a couple times while I have been working on the engine and its leaking between the range trans and the adapter plate (# 10 in the AGCO parts book) and also between the adapter plate & the flow divider housing # 25, could some one tell me what gaskets and or seals I need to fix this ? Thanks Dave
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 7:28pm
You will need 2 of #70269665, 1 of #70929728, 1 of # 70261382, 1 of #70924921, 1 of #70265383 and if it's a power director tractor, 1 of a #70269727. They do offer a seal kit #70271888 that has most everything to overhaul the dual pump. It may be quite expensive since it has the wear plates included. You should also probably replace the shaft seal while there. 1 of #70265398 and 1 of # 70923573.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 10:31pm
The complete seal kit is not available...The other components are though.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 7:18am
Thanks guys, I wanted to be sure I could get parts before I pulled pump, Dave
