8010 AMBAC Injection pump |
AC8010
Topic: 8010 AMBAC Injection pumpPosted: 14 Jul 2017 at 5:59pm |
Mowing hay today and downshifted to get through tough spot and engine took off racing. Throttle back and came back down. Seems like if rpms go over 24-2500 it wants to take off. Finished mowing by keeping on the throttle, but it is very hard to control.Been thinking for awhile that it seemed weak.
MACK
Posted: 14 Jul 2017 at 10:12pm |
Time for a rebuild job. North east diesel at Shelbina, Mo does a good job on them pumps. Also there are people on this form that do good work. MACK
AC8010
Posted: 15 Jul 2017 at 8:30am |
Is the removal process same as 8030?, my 8010 info doesn't show Ambac pump
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5094 |
Posted: 15 Jul 2017 at 9:13am |
yes, same removal and installation procedure as 8030/8050/8070.
AC8010
Posted: 15 Jul 2017 at 11:51am |
Thanks! any idea on cost?
MACK
Posted: 15 Jul 2017 at 10:41pm |
Remove three bolt plate on side of front cover for timing marks. They are hard to see behind gear.
I'm sure InjpumpEd can do you a good job. MACK |
AC8010
Posted: 21 Jul 2017 at 1:01pm |
Got pump fixed and back to running. Governor was bad and needed resealed, got lucky and was only a little over $700.
