8000 series tach Issue
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series tach Issue
    Posted: 17 Mar 2017 at 6:32pm
Went to look at an 8050 today. Tach does not work at idle. Throttle to wide open and it starts working and seems "normal" as long as throttle is wide open. Back off the throttle more than 100 or 200 rpms and it quits reading again. Fixable? Or have to replace?
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 6:53pm
The sensor pickup needs to be adjusted. It's very easy to adjust. Just unplug it and screw it in until it touches the flywheel then back it off one turn and plug it back in.
Thanks & God Bless
Dennis
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 5:31am
Sounds easy enough - point me to the general location of the sensor? Thanks.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 8:02am
Left side. Below the starter.
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 10:41am
Many thanks to both of  you.
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 7:23pm
Ok I have the same problem with my 8030 and I tried to adjust it as said and it still has the same problem, doing the same thing. Like it tries at idle but not enough you have to rev it up to 900 rams to get a response. Any pointers?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 9:40pm
Trouble with an 8000 series tach, join the club. Oh the joys of an old tractor.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 11:28pm
Do you have another used tach to swap out and compare/trobleshoot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 6:14am
Nope it's my first 8000 series tractor so this is new territory for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 4:31pm
The next step is to check the ohms of the pickup. I don't know what the ohms should be. Be best to compare to a new one if you can. Pickups can and do go bad.
Thanks & God Bless
Dennis
This page was generated in 0.233 seconds.
