8000 series steps on a 200
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series steps on a 200
    Posted: 13 Sep 2023 at 4:33am
Has anyone done this? I know anything can be done depending on how much money and fabrication is needed. My 200 steps which I added another lower step this spring still are uncomfortable for me between my left meniscus knee and right bursa enflamed hip. Thanks! Dana
Blue Skies and Tail Winds
                          Dana
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 8:41am
  So are you restricted to right or left approaches???? I liked that step and rail on that 190 posted here the other day. My 200 is going to have a make over also..The 7000 balck belly is kinda far down the project line and those steps are tempting....Take care...Dale
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 11:00am
I added steps from my black frame 7060 to my 200 with factory cab. I’ll go out and get you some measurements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 11:11am
I have a 3 in.² tubing with quarter inch thick wall. It measures 19 inches long. And I had to drill 2 half inch hole and the bolts come up into the bottom of the cab. I drilled and tapped holes for 3/8 bolts that goes through the steps into the side of the square tubing. Then I made a brace from the bottom step up to the battery box. It really has a good feel to it. My 7045 is sitting right next to it and the bottom step height is the same.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 3:53pm
Have you tried the Noonan steps?  I put one on my 190XT and I am very happy with them.  Direct bolt on and nice evenly spaced pads.  The factory steps leave little to be desired by comparison.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 4:15pm
that step above works great if you have two good legs... If you have one weak leg you might want a set of WIDE steps so you can step up, then pull your other foot to that same step, then step up again, etc..... Each step is wide enough to get both feet on at the same time............... plus it can be sloped more like stairs instead of a step ladder.
Edited by steve(ill) - 13 Sep 2023 at 4:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 6:18pm
I think Mike sold the step business and if I recall correctly, maybe to Alex @ Cecil WI??
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 7:55pm
I believe Dale is correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 10:28pm
I bought 2 of the steps like Dseries shows, one set on my 180 and one on my 190XT, i'm going to mount the original step from the 190 onto the side of the battery box just ahead of the fender to help get me onto the platform.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 5:45am
Steve I’ll has got the right idea for me. That’s what I need. Unit3 could you please post a pic? Thanks. Dana
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 6:08am
 I think the 200's step is pretty straight up,making it hard to pull yourself up into the cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 6:25pm
Yes the 200’s steps are straight up. They need to go away😫
                          Dana
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 7:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 8:04pm
from ACs post.....
Edited by steve(ill) - 14 Sep 2023 at 8:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 12:13pm
Yes they’d be perfect!
                          Dana
This page was generated in 0.054 seconds.
