8000 series power director questions
gleaner1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series power director questions
    Posted: 10 Aug 2023 at 4:48pm
Finally joined the 8000 series club.
8050 , with power director bought over the phone and low and behold the hi low pwr shift doesn’t work.
Im used to the buttons on the floor.
I’m assuming I should start diagnosing at the switch, solenoid, valve body? Im not sure how these style are set up. Any advise before I start tearing into it?
And of course no service records or books came with the tractor.
Thanks
ALLIS CHALMERS "The color is orange"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 5:16pm
Make sure the clutch pedal comes clear UP. Hook your toe under it and pull it fully UP. Could be a bad switch on the clutch pedal too, which does the same thing.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 8:30pm
Check the fuse if Dr's procedure doesn't cure it
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 9:03pm
8050 should have the PD switch on steering column not buttons on floor.                MACK
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 11:40pm
I'd start with the clutch pedal switches too.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2023 at 5:44am
Thanks guys. I pulled two panels off the dash, the upper switch must have vibrated up wasn’t even near making contact. The bottom safety one i literally had to stand with all my weight to start it so that one is getting adjusted as well. I’ll try it out tomorrow. Fingers crossed that i have a good pwr director.
Any clutch cable adjustment i should do while under there?
I have no specs to go from.
Thanks
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2023 at 8:47pm
  The wires on my 8050 fall off the magnetic actuator easily behind the power director valve behind the battery.
